Hey folks new problem developed on my 78 restoration . It was running great, I put about 200 miles on it and Saturday it began shutting down on at least two cylinders . Had to be two, big time loss of power and in traffic 55 mph it would hold speed if I dropped two gears but was hard to get going. A minute would pass and then it would pop back on and go ripping down the road only to happen again down the the road. so I limped home on and off power. and suspected a coil as two cylinders would drop together . Don't think carbs or fuel issue would cause that. friend had a coil set off a crashed gl he bought and one coil has a crack in hard plastic shell . It checked out ok as did my old ones. I think mine was failing when hot . I siliconed the cracked coil and mounted them up . Rode a short way and so far so good .. Anybody run a coil with a crack does it work ok ?? I know I could put the good coil of my two in but the connector plug would have to be dismantled and taped up and all to separate them. I have Dyna ignition and the Ballast resister has the a coil scabbed onto it to reduce it further. I would try 1100 coils but the connector is different and the not sure about the 1.5 ohms resistance I need for the Dyna as per Randakks tech. page .. Thanks Randakk
[align=left]Electronic ignition like Dyna-S[/align] [align=left]OEM coils [/align] [align=left] Follow electronic ignition manufacturer's directions regarding retension or replacement of OEM ballast.
Generally, Dyna will want you to end up with a ballast resistance value of 1.5 ohms. This has been accomplished in 2 different ways. Some Dyna installs have provided a "piggyback" resistor to be used in conjunction with the OEM ballast to provide the correct resistance value.
Other Dyna installs have provided a replacement ballast calibrated to 1.5 ohms. In this case, the OEM ballast is omitted.
Just be sure you end up with approximately 1.5 ohm total resistance.
[/align]
[/align]
