1 - 3 of 3 Posts
Now this one I can help with. Sound like the cable needs to be adjusted. You have to remove the shelter, and inner cover, then the ECU and the ABS module (if present) and adjust the cable until the little pointed projection on the cable actuator lines up with the groove in the throttle drum.
Best done when changing air filter and all that kind of thing. You will need a manual also to guide you through all the tupperware removal and all that stuff.
Kit
Paddy also check your micro switches at the front brake and clutch. Kit helped me fix mine with the same symptoms. My issue was the front brake switch. One quick check is does your brake light work properly when the front brake is applied?
Our Guru is probably spot on but with mine he talked me through the issue! Many Thanks again Kit!!:bowing:
1 - 3 of 3 Posts
