Hi guys, I've to start with this new topic although there's comments on cruise control before this but I could'nt find the solution yet. My cruise control is not fuctioning and I've check the followings:
a. Both Cruise check 'on' light and set light is working when the ignition switch turn on and goes off after the engine start.
b. During driving the cruise light'on' when press the 'on' switch and remain 'on' until I off.
c. The cruise set light 'on' when I press the cruise set switch and remain 'on' unless I do the following:
(1) Press front brake lever or
(2) Press foot brake or
(3) Press the clucth lever or
(4) Close the trottle.
d. I've check the cable connection betweem actuator to the carburator and it seem working without obstruction.
So I need help from you smart guys in this forums which I thinks the best goldwing forums. Thanks.
