1 - 15 of 15 Posts
06 GL1800
Cruise control indicator comes on but speed won't set.
Want to start checking switches - found this tutorial, but it claims the brain of the control (and thus the connector where checking stuff is easy) is a box inder the seat, near back, right side.
I have no box there.
Suggestrions/
06 GL1800
Suggestrions/
That is about a 1500, not an 1800, way different. Start by listening to your switches. At the front brake put your ear near it & pull slowly, you should hear a double click. At the clutch a single click as you barely move the lever, on the left side remove the chrome cover above the brake (where you check the oil) and push the pedal, another double click.
Thx~!
I've listened & am getting clicks our of hand brake,clutch, foot brake. But (as i understand) the foot brake is 2 switches, so 1 can be working & the other not.
That's why I just thought - OK, will check them all w/ multimeter
Thx~!
Yes the foot brake and the hand brake both have 2 switches, that's why I said listen for 2 clicks. The cruise control unit on an 1800 is under the false tank.
Try putting your foot under foot brake and lifting up to see if it will set then. Also push out with clutch handle to see if that helps getting cruise to set. There is a brass bushing on clutch lever that wears out, and is replaceable. I usually get 80 to 90K miles out of those.
Chrome after market brake and hand levers also cause problems.
gumbyred
Dang! I have to pull the shelter? What a PITA!!!
Looks like the wires also go under the shelter w/o any accessible connectors.
gumbyred
Believe it or not, this bike only has 18K miles.
Think I'll try WD40 on the foot brake first since that's an easy step. Will also try wiggling the clutch lever & lifting the brake lever.
Wish there was just an accessible connector to check w/ multimeter. Nothing easy ...
02 GL1800 w/Auto Pilot
with that little use, there is going to be some rust on the pivots, use a lot of something and flush out all the pivots.
The cruise on an 1800 seldom fails and when it does it's almost always the adjustment of the switch on the foot brake or aftermarket levers.
I feel bad that I only have 93,000 miles on my 2010.
Discussion Starter · #10 ·
OEM levers; I'll start by cleaning the foot brake switch
Yeah - bought this from a guy 4 or 5 yrs ago w/ only 16K miles after 10 yrs. Thought that was so weird
Now I've had the thing and only put a few K more. How weird am I ??????????
Does the bike look like it was taken care of? Not left in the weather? I haven`t even owned a bike with only18K miles on it for 15 years now. You need to get out and RIDE.
gumbyred
Discussion Starter · #12 ·
Yep. In perfect shape
And yes, have to ride. Longest trip was only 3 hours!
Had a GL1100 for a decade before, but it was a relic I enjoyed for nostalgic reasons & never took it far.
Heck - 4 yrs ago had metal knee put in & got a scooter to get around ... put a few K miles on THAT little thing! Something seriously wrong with me!
06 GL1800
Suggestrions/
Just to be sure, you are saying the cruise on light works but the cruise set light does not turn on and the cruise will not take hold. Is that correct?
1 - 15 of 15 Posts
