had the same problem with mine. I got a can of brake cleaner and sprayed around the switch and let it dry. switch would engage and stay there after that. I then just left my cruise switch in after that.
That's what I meant by 'fixing easily'.Its not a big deal taking the switch apart. Three screws on the bottom of the housing and it will wiggle apart. Nothinwill be flying out. The switch is right there. Use some electrical contact cleaner and clean it out good working the switch in and out. Cover the bike ofcourse. "I" would not use brake cleaner. I have seen it melt plastic before. You could lube the throttle cables a bit too. I do when I have it apart but I usually pull the cables apart and force feed the lube in. Dri Slide is what I use. Good luck. Let us know how you fare with it.
http://www.goldwingfacts.com/forums/2-goldwing-technical-forum/392427-gl1500-turn-signal-switch-fix.htmlWhere can I get a picture of the inners on the cruise control-I hate to take it apart and have springs flying all over-Rich
