So my cruise has not worked since I bought the bike back in the spring.
I went through all the micro switches at the brakes, clutch and throttle. Had to adjust the rear brake switch and now that works, but the cruise still will not "set".
Started working through the plug and socket tests....and found the 4th and 5th gear switches giving me about 4 to 6 ohms of resistance when they both should read 0 ohms.
Seems like they are the culprit, but where do I go from here?
The last solenoid test, between pin 13 and 19, gave me 102 ohms. The specs call for about 82 ohms.
Any help is appreciated
