Hi guys,
My cruise controll is not working. It will show as being on whenI press the on button(shows on the dash) but will not work when I try to set the speed.
Is it somehow connected to the brakelight switch on the right handlebar because I'm having some trouble with that too.
Where will I start?
thanks...
There are switches on the brake lever and pedal and clutch that cancel the cruise so if you are having brake switch problems it could be related.
there is also a switch on the carbs a well, if you roll off the throttle, it will shut off the cruise control.
The set switch could also be dirty. Try blasting some WD40 into it and working it for a while. Keep some rags around the switch to catch the excess. But . . . if you are having brake light switch problems you should probably resolve them first.
