The cruise switch was sticking in the on position when pushed in, so I sprayed with contact cleaner from radio shack and now it will not stay on. I have sprayed several times over a three or four week period. I guess to much of the good stuff. Any suggestions?
Take the switch off the bars and use a compressor dialed low or other low air source ( computer cleaning kit) to blow out all the gunk
oooops sorry I got on the wrong forum!
But since I'm here, how do I get to the switch? I removed the screw on the bottom that holds the unit together (1500). Is there anything else other than prying apart?
ccsailor wrote:
actually 2 screws front and back... just undo and it will come apart Don't pry
Thank you, I had over lookedone recessed screw.
