1 - 19 of 19 Posts
I am guessing this is a touchy subject but I have discovered a CT will fit on a gl1500. I recently built a ST1100 reverse trike. I install a GL1500 rim and Federal 175x60x16 car tire. Total cost was $73 and it should go at least 35k. I run CT's on my GL1800 and Valkyrie and if run at the right pressure they will out do any MC tire especially the radials.
The ST has a similar swing arm to the GL1500 so this tire size should work fine.
Available through http://www.tireeasy.com
My trike project is on http://www.stealth11.com
the CT conversion details on http://www.stealth11.com/ctconversion.htm
02 GL1800 w/Auto Pilot
We have discussed this before, and we have done it without getting into a bad storm.
And we can again.
This is a "to each his own" subject or topic. Please no bad vibes if you haven't done it.
This subject has been flogged to death here and has caused a lot of heated debate so I suggest do a search in the search box you will get plenty of info ,Seems strange that this subject should be the first post for a new member ??????????
I am curious very curious
Seems I cannot stay out of trouble. :D
I will just say short and sweet. I am a DarkSider, I believe in using a CT on the 1800 very much. I have a new one installed, wanting to go play with it but have the flue...ARRRRGGGG!!!
The trike project shows a lot of ingenuity and a lot of skill and is something to be very proud of.
But a trike is a trike is a trike and not a two wheeler. To offset the rear wheel on a two wheeler would be putting forces into play that most have no idea what the result would be, and the word should fit means it has not really been tried?
As one who runs a Run Flat and thinks it is a great thing for the majority of the roads we run on and the interstates, I made a promise I would never say or do anything that would bring harm to another rider.
Things have to be actually tested, fitted, and evaluated, and to offset the rear wheel on a regular motorcycle would bring many forces into play that may be very hazardous , such as a high speed wobble. Not sure about that, but have no intent to find out either.
A CT does lend itself well to the 1800, but that is the only bike so far that has shown real and safe results. Many people will do many things, tis the nature of the human spirit to try. I would have to see this, see it fit, in many ways, I would never just say it should fit.
Ok will behave now.
Kit
Greetings Kit :waving:
I don't think the 1/4" offset would really make any difference but after I was all done I had just over 1/4" of clearance between the rubber and the shaft tube so on a standard 1500 setup everything could stay in stock form.
The only reason I posted this info here was due to some questions on the Darksider forums about putting CT's on Harleys and GL1500 and the overwhelming answer was no it can't be done due to the narrow rim. However what I discovered with this project was that the Federal 175 tire is not only the same width as a stock MC tire but has offset beads so it does fit just as an MC tire would.
I was under the impression 1500 riders had given up on the idea.
There is hope :gunhead:
So now you have me curious!! I may run by a tire store today and take a look at the Federal tires. Shinko a motorcycle tire company is now on the market with a radial tire made just for the 1500 and likewise it has the offset bead.
Many years ago Michelin made a radial for the 1500 but had problems with it so they dropped it.
:waving::waving:
Very nice work, storm! Glad you shared this with us. Welcome to the forum.
Nice engineering on your Stealth trike! jimsjinx
Storm,
I just now had the time to go look at your links.
Nice work, and a job well done.
For your application, I can't see any issues to cause trouble for you.
I just wanted to say after reading about the darksiders I have decided to join them. I now have about 400 miles on my 1800 with the Kumo recommended by Kit Carson. Kit yor are right about the headshake. After installing the Kumo rear and Bridgestone front my headshake disappeared.
Yes I can feel a slight difference in how it handles but I loved it almost immediately.
Dirtbiker
Den
Nothing will pry me away from Pilot GT's.... until something stickier comes along!
My race cans have gain huge damage since these tyres were fitted :D
Thats some slick engineering.......Great looking wheels you can be very proud of that project......well done
Discussion Starter · #13 ·
Thank you gentlemen for the kind words.
Today is a big day for me, I am meeting with a person of interest who is well connected to people in the motorsports arena. This could lead to future meetings with possible manufactures who can take Endeavor to the production level.
On May 2nd and 3rd we have the Inventors Expo in Mpls and Endeavor II will be on display along with all the promotional materials.
The wheels are starting to gather grip!
www.ido-endeavor.com
storm
It would be nice if that video on your link had some audio, just barely hear a whisper
Discussion Starter · #15 ·
AZ are you sure? The audio is pretty loud. check your media volume setting as it may be the one turned down and see if it plays better.
Discussion Starter · #17 ·
Hmmm, well I have tested the video from many locations plus it's on youtube and it seems to be verified. I will have to add a cranker upper perhaps :)
I can hear the volume just fine.........
YOU GOT YOUR HEARING AIDS IN JOHN................... :raspberry: :ROFL::ROFL::ROFL:
I went and tried it again. Adobe Flash video apparently, got a Crash Message in Firefox.
So, I tried the link in Chrome, no audio there either.
Where is the volume control for that video?
I think that the last time I played a Flash video, I muted the volume to keep it from waking up the wife.
Put the volume control on it... at least give folks a chance to change something.
1 - 19 of 19 Posts
