I have a missing cylinder. Number one cylinder is getting fire but I'm not sure it is getting fuel. Any help as to where I start. I have pulled the plug and it is sparking. Opened the carb drain and there is fuel that drains. Carbs have been rebuilt. Didn't see any problems with vacuum pistons on carbs. Sending out a help.
Mike
check the o-rings on the fuel tubes between the carbs. When I got my 82 the PO said it would run well for about a mile then start running rough. It turned out to be an o-ring folded in front of a tube blocking the passage.
Well Guys I don't think I'm getting fuel. Going to check the rebuild on the carb again. Any tricks to priming the carb after having it off. I like to have never got fuel in all the carb last time.
Mike
P.S.
I should have told ya'll the plug is dry. The exhaust is cool to cold after running for a few minutes. So I'm guessing it is missing all the time, including going down the road. Still has good power though.
Discussion Starter · #9 ·
Okay Carb rebuilt and all cylinders are firing. Not sure what it was I didn't change anything and there was no sign of anything in the jets. It is a real mystery. Anyway she is running.
