I'm putting my 75 GL 1000 back together today and can't remember how the cylinders are numbered ( I know i know). The plug wires are still connected to the coils and ARE numbered so that isnt an issue. I'm going to attempt a diagram here so bare with me....
{____ ____}
{____ _____}
heheh. So this would be the view if u were sitting on the bike looking down. I guess repost my message with ur reply and fill in the numbers. (unless u wanna make ur own diagram which im sure will be much better than mine :D)
hey good u got the answer to your questions...:clapper: on the other hand i have one for you .. since you are in the restoration of a gl 1000 did you get to know where to find a set of pistons :baffled:.a good freind neibourg that is rebuilting one (gl 1000 1975)and the pinstons are out dead :bat:he is looking for new , good conditions, or oversize pistons set complete with rings,
thanks for him.
thanks for him.
Norm, I would check with a local Honda dealer if I were you guy's.
My Master Honda tech here has an old DTB (dealer bulliton) that says the bottom ends (crank/bearings cannot be replaced) He say it will freeze up the minute its turned over after torque is applied to the split casing.
Keep in mind this is just what I was told, yes I do trust him. But it would hurt for you guys to look into this prior to completion!:stumped:
thanks for him.
The bike is presently at a local honda dealer who can not find the pistons anywhere
second my freind neibourgh got dicourage and bought a 2000 valk today .
third he still whant to fix the bike which is a bag project now
thanks harry.............
· Other side of the pond
The facts are that the conrod and caps are matched sets, you shouldn't mix & match them. I personally wouldn't ever dream of putting used pistons into my Wing, too much work pulling it all apart again if you get problems.
The cylinder # layout is probably one to have in the new reference part of the forum.
