Mr.1200 wrote:
I Have this Harness on my wing for over three years,
http://www.electricalconnection.com/wire-harnesses/hrns_gl1200_charge.htm
Read the article....These people provide great customer Service.....
Yes it costs $25 more,But your getting a quaility product...
Quality?
1.) Crimped connectors to fail. That was the original problem
2.) Relay armature to bounce and stick, leaving you with no ignition power (it happened to me)
3.) The bit about the "increased gauge of wire"
is utterly false. The longest run of wire carrying high current (in the repair harness) is about 2 feet (between regulator and battery). If the original regulator wiring is (for example):
12 gauge = 0.081" diameter, 1.59 ohms/1000 feet = 0.0016 ohms / foot = 0.0032 ohms/2 feet
and they increase it to
10 gauge = 0.1" diameter, 1.0 ohms/1000 feet = 0.001 ohm / foot = 0.002 ohms/2 feet
thats a decrease in resistance over 2 feet of about 0.0012 ohms. "Times" that by 30 amp (max the system can source for a maximum) and the larger gauge wire drops:
- 0.0012 ohms x 30 amp = - 0.036 volts.
None of us ( me included) have a voltmeter that can even measure a 0.036 volt change. Not to mention the regulator is there to compensate for changes in voltage, so if the change was within the hysteresis of the regulator, it would not be seen.
Besides that, anyone out there ever seen the wires in a GL fail? Sorry, the engineers that designed the original wiring arent ThAt stupid....
Which proves ECare preying on those without engineering knowledge to catch them at their false advertising.
This "wire size" is a similar scam to the "ignition capacitors" someone is trying to sell to unsuspecting 2-stroke riders. $200.00 for a capacitor placed in-line the spark plug with the
utterly fradulent claim that "it increases ignition energy." :gunhead:That violates the laws of physics. A capacitor cannot increase energy.
Seriously, EC is selling what I abandoned years ago because it was plagued with potential failures. It was the second prototype I designed, with an extra $10.00 in useless/needless parts to fail. The relay is there to switch the coils in and out, but it also adds 4 more crimed connectors to fail. Failing crimps are the original problem, why go through it again?
You's guys would soil yourselves if you knew how much $ in parts was in the stupid thing. Its less than you think. Yeah, I sell them for about what you could buy the parts for, it isnt about making money. They never did sell well at $ 40.00 or over, so I abandoned that and lowered the cost.
BROJEES: HOw can I argue with that logic? Cheques in the mail after I finish paying Steve off for my Guru status. That was EXPENSIVE!!!
DEAN: Hey, meybe I can advertise it as "paint remover!" The larger wire removes paint faster!!:action:
