Dead Spot - 08' 1800GL
663 Views 3 Replies 4 Participants Last post by  BenMilner
Hi Everybody! Has anybody had a dead spot between 1000 rpm
to 2000 rpm between the time you start it and the time it is fully
warmed up? Runs perfect after that. 7700 miles total on the bike.
Any help would be great. Thanks Steve :?
Not a problem with mine. Sounds like dealer warranty for you. Tony:waving:
Hi Steve. You might need to re-initialise the ECM by disconnecting the battery and then reconnecting it. Then start the engine and DON'T touch the throttle until the engine warms up.
7700 miles means new spark plugs unless you replaced them already. That will cure the cold start flat spot.
