Left front fork has decals stuck on it. They appear to be decals granting access to a naval base. Anyone know the best way to remove these things? I don't want to scrape them off and risk scratching up the finish on the forks. Advance Auto has some decal remover but if there is a homemade solution I'd rather go that way.
Thanks! :waving:
Just one of the guys
A Heat gun used gently to loosen them then use goo gone or something similar for the residue that will likely be left behind.
Probationary
I use acetone [nailpolish remover] and a piece of plastic to scrape them off. I've never used it on a bike's windshield ... just unpainted metal and auto glass.
Aircraft paint remover works, too [protect paint first] , on non-painted metal areas and available from NAPA stores + an excellent wheel cleaner. The aluinum paint remover will also remove the yellowing varnish from the forks of older bikes.
I have used WD-40 to get stickers off. Let it soak a bit then rub off with a cloth.
That's the method I've always used. Heat guns can be pretty hot so just hold it close enough to get the sticker pealed off and then wipe it down with goo gone. I've even used a hair dryer when I've been without a heat gun.
2nd on the WD, or mineral spirits(won't hurt plastic or cured paint) but will remove old wax from original paint.
Aircraft Stripper will do the trick very quickly too as mentioned but don't get it anywhere else. Just removed a decal from my lowers to polish them up. I used a drop cloth or old towel right behind each fork leg to keep it away from everything else.
