1 - 14 of 14 Posts
I am in DESPERATE need of a COMPLETE points set up (points, condensor, wiring, plate, etc) for a GL1000. I have to pull my Dyna ignition off my bike and send it to them to be tested....so, my bike will be down indefinitely unless someone can help me out here! Does anyone have one of these setups laying around? PLEASE?
I can probly help with the points plate . Let me check after work today . Aren't your condensors still mounted to the coils ?
domscorpiorig---pm sent
RB,
Thanks! I looked on Ebay a day or so agao and those didn't show up. I just messaged the guy about them. I am curious though....someone said there was a "cam" mechanism that I would need as well....does that sound familiar at all? Or do I just need the points and the plate (with the wiring of course)? Please let me know when you can. Thanks!
I bet the condensers are still mounted on the forward end of the battery box. And you also need the cam and mechanical advance thingy...
Ok...so, HOW do I get the cam and the mechanical advance? And does anyone have any "directions" on how to install all of this?
i`ll send a copy of the inst. too.
pm---sent
if you have questions ---ASK ! some one will know---i`ll bet.
pm your e-mail and i`ll send a pic of parts sent . me being the dumy on this computer---dont know how to post a pic in my replie.
Curious what happened to your Dyna. I've been considering replacing my points on my GL1000. I heard others say that at least with points, they can be repaired if they go bad.
I have a 1977 gl1000 parts bike. I think all the points setup is still there. If you still need anything that is. I'll check and get back with you.
Discussion Starter #13
Well,
I got the points set up on the bike, but I didn't do something right, because all it does is backfires. I've got to go back and set the base (initial) timing so I can figure out what's going on. My dyna system failed me, and I am sending it back to Dynatek to get it checked. I am losing one side of the engine firing as far as power goes. I've had the carbs rebuilt twice and thoroughly checked. I've replaced the wires, the coils (both brand new, both from Dyna), the resistor caps, the plugs...the only thing left is the Dyna system. Going to work on it again Saturday (with any luck, if it isn't raining too hard).
domscorpiorlg wrote:
Well,
If you still have problems after looking at it, post this question in the Tech forum. Not many people will be looking in here, to see it and offer help.
1 - 14 of 14 Posts
