1 - 3 of 3 Posts
I bought a set off of Ebay last year. They work ok, but the seem a little dry and stiff. Do they take oil like the stock shocks? If so how much and do I put it into the air inlet fitting?
Also where can I get some new airline fittings and tubing? I basically want to re-build the whole system from the compressor to the shocks. Thanks in advance folks!
Hi Poolguy, the following is copied from a Progressive installation manual.
[align=left]Caution: Under no conditions should more oil be added to the air[/align]
[align=left]chamber. The maximum recommended volume of oil with Progres-[/align]
[align=left]sive Suspension air shock or replacement damper cartridge is 2 oz.[/align]
[align=left]Use only Dextron ATF fluid or Progressive suspension shock oil. Or-[/align]
der no. 5081
1 - 3 of 3 Posts
