In a way, my electric clutch design has a "hold" position, for traffic, and a "go" position for driving. Right now , it has been tested only on the bench. This is the main reason I was trying to find out how much force is required for clutch dis-engagement. I did know about the tractor idea, but thought it to be too complicated on my finished design.You must have just been aching for someone to ask the right question for you to post a picture. What a beauty! You should be proud.
As for the clutch issue. Why not fabricate some type of detent where you can disengage the clutch and have it lock in to a "detent?" Tractors use similar things where they apply the brake and actitae the detent to hold the tractor in place. Bump it and the detent disengages. Could that work for you? With the fabricating you have already done it seems this would be a piece of cake for you. Just my suggestion.![]()
Well it looks like you have built your Motorcycle into a 3 wheel car. So why not set up the controls just like your car. Use your feet for Gas, Break and clutch and steer with your steering wheel. All of this was figured out a long time ago, as the best way to drive. Also shift with your hands, Feet are much stronger than hand grip for holding pressure Good Lucky and your car looks pretty cool. . Might look around a wrecking yard and find a set of pedals from and old VW might be a good place to start.
JerryWell it looks like you have built your Motorcycle into a 3 wheel car. So why not set up the controls just like your car. Use your feet for Gas, Break and clutch and steer with your steering wheel. All of this was figured out a long time ago, as the best way to drive. Also shift with your hands, Feet are much stronger than hand grip for holding pressure Good Lucky and your car looks pretty cool. . Might look around a wrecking yard and find a set of pedals from and old VW might be a good place to start.
I have a foot brake and gas pedal. Sadly, no room for a foot clutch, which would have been great had I thought of it when I was thinking I could use the hand lever clutch. Hind sight is 20/20.
