Folks,
We just installed a new hi-output alternator (85 Amp) in my friend's GL1500.
This is not a Compufire unit (too expensive for his budget). It's an LA Electrical (LActrical) 85 amp aftermarket unit.
I've read that when installing a Compufire alternator you should replace the bike's main 55 Amp dogbone fuse with a 110 Amp one. I think they actually do that by installing two 55 Amp dogbone fuses one on top the other.
So, my questions:
Does he NEED to install a higher rated main fuse now that we've installed an alternator that can put out 85 amps. Or, can he make do with the 55 Amp main fuse as long as he doesn't load up his bike with a ton of accessories and lights that pull more than 55 Amps combined?
If we NEED to, i.e. MUST, where the heck do we get an 85 amp main dogbone fuse? Do we just double up two 55 Amp fuses and go with a 110 Amp main fuse?
Also, what about the battery. Is a stock Yuasa battery for a stock GL1500 going to be OK with the 85 Amp alternator charging it?
All experience and advise would be greatly appreciated.
Thanks.
So, my questions:
Thanks.
