1 - 3 of 3 Posts
Ole Guy
Today I am lubing the final drive and splines. Can the U-joint be lubed? I’d rather not tear into it if there is nothing to service. I looked at the parts breakdown and manual but it made no reference to servicing the U-joint.
Older and Wiser
You can apply some grease but it might not get into the sealed bearings and will get flung off when teh shaft is spinning. Some of it might stay there.
No need to lube. Just make sure the gator is good. If your is currently in bits then it would be wise to replace.
Getting the springs back on to hold it in place was a real swine!
1 - 3 of 3 Posts
