I MADE THE METAL BAR AND IVE JUST HAD IT RECHROMED ITS EXPENSIVE BUT GOOD.BEND IT TO THE SHAPE YOU WANT.IT MUST BE AT LEAST 1/8th THICK TO STOP THE LIGHTS FROM SHAKEN THEN DRILL TWO HOLE S IN THE FRONT FOR TO FIT ON THE BOLTS WHAT ARE ON THE FORKS,AND THEN TWO HOLES IN THE SIDE S FOR THE BOLTS TO GO IN .THEN GET SOME CHROME TUBE CUT THEM INTO TWO SECTIONS FOR EACH SIDE,AND FIT THEM IN BETWEEN THE TOP OF THE LIGHTS AND PUT A CHROME DOOMED NUT ON THE END AND THERE YOU HAVE IT,I THINK IT LOOKS BETTER THAN THEM OLD BRACKETS WHAT YOU GET WITH THE LIGHTS.BUT IT S UP TO YOU.TO WHAT YOU LIKE BEST ,:jumper::jumper:
