Hi,
I just finish the instalation of LED DRL (Daytime Running Light) or Aux Light on GL 1500
IT IS SOO GREAT I DECIDED TO SHARE WITH YOU GUYS.
Very simple and efficient.
1. Removed the two 6mm allen bolts holding front of fairing Under headlight and replace them by 6MM X 50MM
2. Simply added a spacer made of alluminium 20MM diam X 32MM Long with a 6MM hole (I polished mine dont have to )
3. Install bracket (supplied with light) and make sure to keep the washer/Spacer to prevent braking the rairing.
4. Install, Plug and ajust new light.
Here is a link to my album showing the steps. and results.
http://www.goldwingfacts.com/forums/members/86886-dj-norm-albums-front-aux-lights.html
Here is a link to the Light I used very good, 10 Watts, LED and good lord bright and efficient
http://www.superbrightleds.com/more...watt-led-mini-auxiliary-work-light/1386/3270/
Very nice looking install. My question is, when are you coming over to my house to do the same install on my wing???
OUfff I think the ratio is not good 10 Hrs ride for a 30 min job huuuuummmmm:)
will you do mine too?
if you guys bring the bikes to me it will be a pleasure to do them and lead you for a great visit in old quebec city ,,,,, cheers
