I have owned this Wing for the last 9 years and I believe that it was fitted with Bridgestones when we aquired it. Did not like them at all as the Wing followed all the lines in the road.
I ought to point out that my partner, Denise, has osteo-arthritis, so we like a smoother, softer ride and have the standard GL1500 suspension.
The first set of tyres I fitted were Metzeller ME880's . These were fairly good but suffered from cupping unless run at a higher pressure (40+ psi) which made them too "bumpy".
I had 2 or 3 sets of these before changing to the Michelin Pilot GT which I thought were fantastic, apart from the whine from the rear tyre. They wore quite well and could be run at 34/36 psi giving a smoother ride, but then Mitchelin discontinued them hence the change, after a lot of research on this forum, to Dunlop E3.
That's when my troubles started, I think. I have to point out that although I usually change tyres "as a pair" I had to replace the rear Michelin to an E3 early as it was attacked by a screw making it unuseable. I replaced the front some months later.
I find that the E3 tyres make the Wing more of a "handful" than it should be and would go back to Michelins in a flash, despite the whine.
It's a minefield out there for tyres and riders have different opinions on what is good or bad, dependent on many factors (riding style, wear, grip, etc)
I just want a comfortable smooth ride and I am not one for throwing it round twisties, tearing off at breakneck speed (although I do ride to the maximum speed limits) or riding in torrential rain (if I can help it). I want to cruise and admire the countryside, get there safely and enjoy the whole experience.
Is that too much to ask ?
Any (all) thoughts regarding tyre selection appreciated and it looks like I will be having a set of nearly new E3's for sale ! (not really as I need to get some value from them so I will experiment with pressures)
Thanks everyone. Special thanks to Satan for his pleasant, informative and comprehensive PM's)
