Picked up a '79 'wing that has had the original carbs removed and a homemade intake with a Solex 28 installed and the points replaced with a Dyna.. Rode it home, no bottom end, not to bad above 3k RPM.. So in I go (after redoing the cooling system. hoses, radiator sent for a visit to the radiator shop, new stat) to attempt to get the bottom end and idle straightened out. Plugs are OK, coil is close (going to replace it anyway, found some cracks when I pulled it for a visual).. Off to the timing. Way retarded when I went to adjust the left side, get it where it should be and go to adjust the right one.. The test light acted weird, dim light.. Wouldn't adjust.. Poking around here and elsewhere I find it's not uncommon for them to butt up at the top and not have enough adjustment.. Fine, split the difference.. Fire the bike up, anything below 2k and it goes to stumbling and dies.. Ugh.. Ok, this sux.. Fuel or ignition?!?! Poke at the Solex a bit, spray carb cleaner looking for vacuum leaks.. Nada.. Ok, poke at ignition more.. this is where it gets a bit strange.. On F2 I get 12v on both leads from the modules.. Rotate the crank towards F1 and both drop off.. (Forgive me as I'm not familiar enough with wings to remember which coil is which module).. The lead from the left drops to 0 volts, the lead from the right drops to 7 volts.. And stays 7 volts past F1 back to F2 when both come back up to 12 volts.. So, I guess a call to Dyna is on the agenda for tomorrow. Looking for ideas as after tomorrow the weather here is supposed to drop back to below the comfortable riding level again
