1 - 9 of 9 Posts
After having my ride for 7 years with never breaking down, it broke the pull part of the throttle cable at the grip. I managed to get safely into a parking lot to assess the situation. I have the OEM tool kit and so I took the throttle assembly apart, hoping to find an easy fix. Nope, not happening. I used somecreative thinking and figured out that I could use the pair of pliers to pull on the cable by gripping real tight and actually rolling on the throttle using the grip as a pivot point of sorts. Made it back home without much to do and was safe. Wish I'd had visegrips but oh well.
Now to my question: anyone using Motion-Pro cables? I'm probably going to go ahead and replace the clutch cable too.
If not what is the general consensus of a good manufacturer of cables(besides Honda OEM)?
Hobie:waving:
I have had very good service life from Motion-pro cables on dirt bikes, snowmobiles, ATVs and just put a Motion-pro speedo cable on my 1500 last night, I thing they make a good replacement and a lot less coin than OEM
Have had Motionpro throttle cables on my 83 Aspy for 2 years no problems at all and they fit perfect.
Thanks for the replies, guys.:thumbsup:
I'll pick up the set. Might go ahead and replace the clutch cable also and lube the tach and speedo cables too.
Hobie
i put a set on mine in 06 . fit perfect and still doing there job. just lube them with cable lube before you in stall them.
They're ordered and I also got the cable lube attachment and their lube. I didn't go OEM because I've had very good luck with aftermarket and have saved some cash in the process.
I'm involved in two hobbies at the moment. Only have money for one....:sadguy::cheesygrin:My new S&W MP15 Sporter AR-15 is due any time now.
Btw, I hope that the cables I have for my '79 won't work on the '83. Hmm, just thought about that. It appears they have different part numbers. Hmmm.
Hobie.
BTW, thanks for the replies!!
Vintage Rider
Motion Pro makes excellent cables, at least oem quality. Plus they will make any cable in any length, though it isn't cheap. I have Motion Pro cables on my dual sport bike, and carry an extra throttle and clutch cable. But I have never had one break.
Your method of getting home reminds me of how I dealt with a broken throttle cable on a VW bug about 20 years ago. Myself and a couple of other people had been to the beach flying kites, and were on the way home when the cable broke. After thinking it over, I removed the broken piece of cable from the carb, and tied a piece of kite string to it. I ran the string through one of the vents in the rear lid, up over the top of the car, and through the vent window on the drivers door. I used that as a throttle the rest of the way home. Try that on one of these newfangled "fly by wire" systems, ala Toyota.
:applause::cheesygrin:+1
Hobie
1 - 9 of 9 Posts
