Been doing some research on electric fuel pumps and was wondering which one for my set-up! I have a CI Holley single carb conversion which I've run for about 8 years+-! I'm looking at a Facet fuel pumpwith a2-3.5 lbs. flow, rated 15gph or one 2-4.5,rated 30gph. Both pressures I can handle, it's just the GPH I'm uneducated about!! Which one would work, a higher or lower gph:?!! Thanks :cool:Bob
Match it to the specs for the Holley carb, don't want to starve it to death.
Piled Higher and Deeper
Either of the two would work.. and the larger flow is not an issue; it will deliver only what you need... but the smaller is plenty (100 hp needs about 8 or 9 gph)
