I'm dubbing away at the GL1000 I picked up and I have been trying to do some electrical troubleshooting. I can't get it to crank by pushing in the start button but if I short the two big terminals on the starter solenoid it will turn over fine. While I have been off and on working on it I disconnected the negative battery cable. Here is something I'm confused on. Just the positive battery terminal is connected. When I take my trouble light and hook it to a good ground, I find that there are several wires that are hot even though the battery doesn't have the negative lead hooked up. For some reason I was under the impression that if both battery terminals weren't hooked up nothing should have power showing, no trouble light should work, etc. Am I missing something here guys?
One last thing, I was trying to confirm if my starter solenoid was bad but something I read said to check the neutral switch. Is there a neutral switch on a 1977 Goldwing and if so where is it? I supposed checking out the Neutral Switch may not be as important as answering my dilema/question from the first paragraph. Thanks in advance.
