This happened a couple of times when braking. The radio will cut out untill I release the brake,(front or back) and both signal light indicators in the dash will light up,(not as bright as normal), while the brake is applied.
As well, when I release the cluch leaver to accelerate, the same thing happens. Its only happened 3 times.
I recently replaced the relay for the tail lights/fuel and temp guage(one relay) because it went. I'm wondering if this might be another relay problem or possibly something else???
Any ideas anyone?
You have a bad ground connection somewhere. Knowing what bike might help locate the problem.
I'm with Dave and add this. If you find that all the items share a common ground that is the one that is bad in all likelihood. I'm betting current is seeking ground. When it can't find a ground it back feeds through the turn signal indicators and uses the ground for those lights. That is why they glow. It's not an open ground just a poor connection. Probably lose or corroded.
