LOOKING FOR ELECTRICAL DIAGRAM FOR 1999 WING i am having trouble with my neutral switch
Good luck.
02 GL1800 w/Auto Pilot
Hello Wiz;
see you are a new member to the forum. Would you please click on "My Account" on the right side, and then click on Profile? There is a place to enter your location.
That will help a lot in recommending the proper actions for you. This forum has world wide coverage and is extremely active.
You get better service and we learn to know you better. :)
Are you sure it's a wiring issue? Next time it happens, or if you are having trouble now, try wiggling your reverse lever and reset it in the off position. If that thing isn't seated right, or needs adjustment, you will not see your neutral light, and it won't start.
