I'm new to the goldwing community, but not to bikes. I bought an 1982 GL1100A. I've been over the entire bike once. Valve clearance adjustment, oil change, timing belt change, etc., but haven't messed with the carbs. I noticed on cold starts, Florida cold (75 deg F) there is an occasional popping from the cylinders, no smoke. After 10 seconds it's gone. I haven't been using the choke here. Having nothing to compare it too, is this normal for this engine?
Not really normal to have popping on a cold start. I'm not too clear exactly popping is. Backfiring? Missing? It might be difficult to do much about if it only lasts for 10 seconds. Try using the choke on start up and see what that does.
Welcome to GWfacts.com!
I agree with "exavid" try a half choke and then a full choke even though it's 75 degrees and see if it pops? Let us know !
Not all Bikes run the same (quirks) try changing your octane after each tank !
should run regular 89 oct but see if it pops with a dlfferent octane ?
What brand and size plugs are you running?
You're welcome from all of us and thanks for the final report so we can learn also !
having a 1000 and a 1200 I know that cold starts (and oklahoma summers are anything but cold) they both run jerky for the first bit, playing with the chock helps, but wings have been known to be "cold natured" at start-up
