I would use definitely use 20w50 oil, and since the 1200 has hydraulic lifters like a car, they could be gummed up a bit. I would try a little Seafoam in the oil. Theoretically hydraulic lifters are supposed to run with zero lash, but if they get partially plugged up, they may not pump up properly, or if they are badly worn, they could be leaking, which would cause the same problem.
