Hello,late last season I was on my last ride and on the way home. I noticed a noise that came out of the speakers like the engine rpm's and it seemed to start about 55mph, below that you could not really hear it.. The radio was turned off. I have a stock radio on a 85 1200A, all that I added was a volt meter (weeks before) and went to the fuse box with the hot and ground,is there any type of inline noise filter that may have gone bad?
Thank you
Joe
Disfunctional Nimatode
If my radio gets damp...... it will sound like that and it was the intercom button turned way up.
Make sure you are running the correct plugs for your bike. If it calls for r plugs check that first. Also check to see if you have stock Plug wires and if they require resisters in the plug caps.
Thanks all,I did replace the plugs late in the season and the grand baby's where playing around the radio. I plan to replace the plugs again in the spring and check the pa on the radio. Thanks again.
