morr,
Make sure you drain some oil out before you add any Sea Foam or MMO! You don't want to over fill it.
When Iuse Seafoam I add 6 or 7 ounces, run the bike 200-300 miles then change my oil and filter. You may need to do this a couple of times. Or you can try adding more to the crank case. I wouldn't add more than a pint (16oz) though. I have never used MMO but people on here who have, stated they add 1 quart, run it 200-300 miles then change the oil and filter. The more you add, the thinner your oil gets. You can add Seafoam to the fuel tank also, at the ratio of 1oz/gallon. Helps clean up carbs etc.
Now that I think about it, I'm not sure you can get Seafoam over there. Maybe someone who knows for sure will post. I'm sure you can get MMO though.
As Dadoo stated, you could just need a carb balance.
Bob :11grey:
