1 - 3 of 3 Posts
Just picked up new (used) goldwing with 5000 miles and noticed that in the quiet of my garage with the engine idling at normal temp I hear a slight tapping from the engine cases. Is this normal? The previous owner stated that he put in synthetic oil. Is this OK? Also my Harley helmet with a 7 prong connector will not fit the 11 prong connector on the goldwing. Is there an adapter I can use? Thanks for your help! Nervous new father...
Scope Down
BH
:waving: The wing has a 5 pin connector, the hardly has a 7. So you need a 5 pin set up to use the headsets on any metric bike, including the Wing.
J and M might have a lower cord that will adapt the harley gear to the wing, might, that is where I would start looking for something.
Tapping? One thing for sure oil has nothing to do with it, could it be the fuel injectors firing? I am not sure what you are hearing, sometimes in a closed garage I can hear the injectors fire.
Kit
Synthetic oil is not a problem, it is commonly used in Goldwings. Some people won't use anything else.
Most GL1800 engines have what I would describe as a "clicking" sound that comes from the fuel injectors and can be heard at idle. Soon after I bought my 05 I took it back to the dealer to ask about it. I don't even notice it anymore.
As far as the headsets are concerned, Kit is correct. If you have the J & M brand headsets all you need is a new lower cord.
1 - 3 of 3 Posts
