my 82 aspencade has a very slight leak out of the weep hole on the water pump, slight as in overnight about 2 or 3 drops. Is it acceptable to try the stop leak that claims to swell and rejuvenate seals or is there an adverse effect on the fiber material on the clutch discs? I know I should pull the cover and pump and I will one day, but until then, what does everyone think? Oh, I have not used anything like this on a bike, but have had some degrees of luck with it in larger engines.
thanks
thanks
