Hello all,hope all is going well for everyone. Quick run down,I bought this as a project
and fixing little things along the way.First road trip was a nice 400 plus to shake out
any loose ends.Noted on return leg that when nice and warm on decel and light throttle action there was small rattle.Engine area,seemed to be upper end,like some
bb's bouncing around.Never seemed to get worse on way home,set awhile due to clutch master going out til had time to build and finish moving.Repairs completed along with front and rear brakes and have noted is getting worse.Noted when warm
at idle after has warmed up noise comes and goes.Raise rpm's slowly gets louder til
about 2000 rpm and fades away,back off throttle comes back in. Hard to really tell if
upper now or lower but swear after all my years in cars it sounds like a darn worn
rod bearing or cam bearing.Has 79K on it and set up 7 months or so before I bought.
Any of you guys or gals experince anything like this before?Thanks for your time and
thoughts,much appreciated
