1 - 2 of 2 Posts
Has anyone done the swap out there any info would be appreciated. I know the ignition is different as the 84 is in the rear and the 85 is in the front of the motor. Any help would be great. Thanks in advance Jimbo.....:waving:
i did the 85 to the 84 and it was a piece of cake. you'll have to dent the gas tank to clear the stator housing part of the engine and you'll have to rewire the pluse gen to the 84 but the wires are long enough to reach and they are the same color. i can't remember anyother problems i had it was a pretty easy swap. oops i just saw your 1200 is an aspy if it had the gear shift indicator you may have a problem there if the 85 doesn't have it mine where both out of an interstate. i mean it'll still work you just may not have the shift indicator.
look up starter for dummies lets put an 85 on an 84 help.:clapper::clapper:
1 - 2 of 2 Posts
