1 - 3 of 3 Posts
po undone fan.and put in toggle switch been looking for plug to hook up fan and test thermo.been looking for about 3 days.the wires comeing out of fan are a solid black and solid blue.the plug i found wire is solid black. black with blue trace.hope this is what i have been looking for.want to test thermo switch.if bad put metro geo switch in and jumper wires to keep toggle switch.also what are napa no. for rad hose.going to pull rad.to fix switch.and want to put new hoses.i know this is long winded.but want to do it all before rideing season
THANKS ALOT (ALAN):waving::waving::waving:
Thermo switch is located on the right side of the thermostate housing and if memory serves me correct it has a blue & black wire. You need a 1 1/16" deep socket to get it out.
Do a search for the Geo switch part numbers? Lots of info on what people have done to install this switch. Also on rad hoses. Check the how to do area?
I did the Geo switch & napa rad hose and works well.
The fan switch has 2 wires one is blue&black and the other is solid green.
I saw on eaby were they are selling the fan thermostat switch that triggers the fan at 177 degree for around $50.
1 - 3 of 3 Posts
