1 - 3 of 3 Posts
Hi all.
need some help
Rev counter has developed an intermittent fault.
At Idle it is reading 1200rpm (should be 8-900)
at 30mph reads 2000rpm (should be 1200)
At 60mph reads almost 4000rpm (should be 28-3000)
I have checked voltage at rev counter, all ok. ( getting battery voltage of 12.8 volts)
I have cleaned all contacts and the main plugs in wiring harness at instrument panel.
I have checked relay 3 and exchanged it for another relay, No difference.
Checked all fuses
Cleaned all earthing points.
Bike did this for about a week then problem cleared up. Has started again out of the blue.
Is possible resistor in counter has gone bad? :? :? :?
Any and all help greatly appreciated.
Many thanks in advance
"at 30mph reads 2000rpm (should be 1200)"
That doesn't sound right, 1200rpm at 30mph seems way low to me.
Sorry/
Should have read at 30mph reads 200rpm (should be 1500)
1 - 3 of 3 Posts
