1 - 3 of 3 Posts
Loyal member
Hi,I need to replace the pinnion seal and am looking for any good words of wisdom before starting this project.Thanks,moon
Junior Grue
You'll need a pin wrench/socket for the seal carrier but other than tht it's straight forward,
By the way are you sure the seal is bad? There are a couple of feed holes that leak fluid to lube the shaft splines.
Loyal member
Ken thanks for the reply and yes you are spot on,after removing the final so I could inspect it closer it was indeed the lube holes.Thank you and this site for a wealth of info,moon.
1 - 3 of 3 Posts
