Is this a type 1 or 2?
Thanks,
David Aka Nightrider1
Thanks,
from what i see here . the cb is the only thing that you could add. it has intercom , am / fm .
and a missing button for the men/ adj . the adj is for the clock , the men is for the radio station select buttons .
:cheeky1wda-83wing wrote:from what i see here . the cb is the only thing that you could add. it has intercom , am / fm .
wda-83wing,
I found that out the hard way. I have to set it with a tooth pic. Once I set it, I just put the toothpick in my right holder. Works well.
Thanks Brother,
David
John,The blank is for the CB radio. You will need the control unit for the radio face, the handlebar switches, the display and the CB unit that mounts inside the fairing along with the appropriate wiring.
John,You WILL need the control unit for the radio face. Also there is a box inside the fairing that houses the tuner. In your avatar, I don't see the station display on the dash. The antenna splitter, as mentioned above, must be there. I can send photos later if you need.
