OKay, my entire post seemed to vanish when it posted.. guess I shoulda hit the preview button
I recently aquired a 1980 GL1100 that I am currently changing out the timing belts and fluids on. When I removed the oil filter housing after wrecking the bolt(it was literally PAINTED on!), I discovered that the "Sealing Ring" that goes between the spring and filter was missing. Is there a replacement size at the Home Depot or Lowes that I can pick up, or am I going to have to hit up a dealer for this little fella? Does it actually do some "sealing", or is it there mainly to separate the spring from the filter's rubber gasket there?
Thanks,
Sam.
Thanks,
Sam.
