I purchased a 98 GL1500SE a few months ago knowing that it needed the starter gear replaced. I believe it sat for a few years. The major work is done, I have just gotten the motor back in (still hooking everything up). I rebuilt the carbs, timing belts, new oil, plugs, filters and vacuum lines, cleaned gas tank, rebuilt petcock among other things. I have turned over the engine (on the bench to check compression) is there anything else I should be aware of before firing it up the first time?
Tires, rear end fluid, lubing driveshaft, flushing the brakes and clutch, servicing all the switches, the compressor and suspension will be happening after I hear it run
Any other suggestions are more than welcome!
