1 - 20 of 38 Posts
Here is what I did today it solved my leak from the site glassand also incorporated my other favorite pass time of treasure hunting. If this holds up I'll probably put a barber dime in the clutch master cylinder :cooler:here is a picture of the finished product, needs cleaned a little more but I like it .
Ride Safe, Ray
:action:
How much was that dime worth?
probably a buck depends on melt values :)
Nice Job, I want to see the Barber dime in place.
:clapper:I like it to:clapper:
Thanks guys! I want to see the barber dime in there too, just gonna make sure everthing is ok with this prior to me removing glass and all. Took me a hour of preping the coin to fit properly, I used the old coinring makers method to bring the dime to size as I didn't want to distort the dime any more than I had to( site glass hole was .667 and dime was .700).
Thanks Again, Ray
:action:
gotta love the wing wrote:
Nice job!:clapper: Did you epoxy it in?
I used JB Weld on her and let it set for 24+ hours.
I have finally decided to put a barber dime in the next time I get a chance and it is raining for 2 days straight. The hardest part is getting the coin to size, not really hard you just need to take it slow and easy so you don't get her out of round beyond repair:)
I'll update when I get it finished:waving:
How do you do that?
Discussion Starter #11
I use a small tack hammer and gently tap the coin while rolling it on its rim(stress tapping no power hits:shock:) take a set om micrometer and measure inside diameter of site glass and measure the coin. Silver is soft and you can form it pretty easy by taking your time. After I got the coin to size I then polish the rim till smooth ( best to leave .004-.01" prior to polishing to allow room for error :) test fit until it fits snugly.
Hope this helps, Ray
:waving:
1985 GL1200 Limited Edition
Now THAT'S pretty slick!!! :shock::coollep::coollep:
Hey ray. i thought I was slick for re repairing mine with dimes from the same yar as my bike.
You have a way with things my friend. It looks great.
Discussion Starter #15
kylesmuskie wrote:
Has anyone ever thought about the purpose of a sight glass ? :D
I was wondering when someone would say that :cheeky1:It is a regular maintance soI'm not too concerned about it :)
I replaced mine with a piece of clear plastic, after letting it set in brake fluid over night to make certain it would handle it.
I do like the touch with the Mercury dime.
Funny how you see things done with coins.
I don't know what happened to it but my dad carried a good luck coin with him. It was a walking libery that someone had taken #8 bird shot and given Lady Liberty a personal adornment!!
How they figured it out I don't know, but when you flipped it over guess what it gave the eagle??
That looks really great. What a good idea.
Discussion Starter #20
glad it worked for you, just make sure you let everything setup for a while before adding brake fluid:action:
1 - 20 of 38 Posts
