1 - 20 of 25 Posts
I need help fixing a fuel injector pump for my 1985 Goldwing Gl1200 LTD, it was seating Iddle for over 10 years.
Post this in the tech forum. You'll get plenty of help then... and welcome to the best goldwing forum around :action:
Gregarious Greeter
[align=center]
[/align]
[align=center]Welcome RayDiaz[/align]
WELCOME:waving::waving::waving:
The Irish Crew
Welcome to the forum. Have you tried tapping on the outer casing? Sometimes that frees them up after a long rest.
Welcome to the Forum, a great bunch of Wingers. Sorry but don't know nuttin about fuel injection,but sure others here will come to your rescue.
Jim
Discussion Starter #11
Thanks FitzAl, I'm working on that with some carburator cleaner, lots of brown stuff coming out. I'll keep youposted.
Just want to clarify. Pump gets power just doesn't turn?
Mine was sitting for 5 years, same problem, all efforts to fix it went no where. The best solution is the airtex E8000. It's almost a direct replacement, it's just a little smaller in diameter, but they include a rubber bushing to make it fit better. You can get it at autozone for about $100, part number is E8000.
Also, might want to replace the pump relay while you're at it. When I replaced my pump it only took about 30 minutes before the relay cooked.
It was fourteen posts before wingsam asked if he has power.
The original post was "I need help fixing my fuel pump".
blackknytecnc posts that his pump did the same thing, but there are no symptoms listed.
Did we jump to conclusions on this one?
Just what is the problem with the pump that it needs fixing?
1985 GL1200 Limited Edition
It don't work.....:cool:
Thanks for clarifying:gunhead:
1 - 20 of 25 Posts
