Help, Please. I have a '98 GL1500 Asp. My right turn signal stopped working. We checked the fuses and the fuse was blown. I put in another fuse.... gone again. We pulled the seat and all plastic up to the front turn signals and the rear trunk. The turn signal relay was burnt out. Bought a new one and .... burnt that out too. Why don't I learn. The wire White with green stripe is where the burn/melted relay was. The side that melted was the side with the metal wire that you can see to the left side. The other two leads go into a circuit board. Low and behold this relay still works even with the case melted. I checked all 4 bulbs and all look perfect plus we exchanged each from the right side to the left side and the bulbs work fine. We pulled both right side bulbs and the relay still started to burn again. Getting back to the fuse, the fuse blows only when we hit the 4 way flasher button. The fuse does not blow when we just turn on the right turn signal. Again, the left turn signal is working perfect. The 4 way relay seems to be fine, it is the flasher relay that burns up. One last clue, when I turn on the Left turn signal every thing works normal, when I turn on the right turn signal all the lights on the bike go dim then normal, dim then normal. It is like the flasher relay is operating all the lights a bit. Even the bulbs for the right turn signal show just a small drop of light as it should be flashing. I don't know where to go from here or how to check what is wrong. Any help would be appriciated. Thanks guys.
