For the brake lights check the adjustment on the switch , there should be a spring from the brake pedal to the switch near the rear master . Also check the front brake handle , there is a micro switch on the handle bars which also operates the brake lights . That switch could be stuck . Might be asimple test to unplug the switches one at a time and see which one is causing the light to be on .
The turn signals have a "Winker Cancel Unit" under the faux tank . It is operated by the" Angle Sensor" ,located on the bottom of the steering stem . It is also operated bya "Speed Sensor" signal from the speedometer head . So once you turn the handle bars and straighten back out they should cancel ( as in turning at a stop sign ) or they should cancel by a speed signal ( as in passing a car where you dont turn far enough for the angle sensor to cause a cancel .
If your turn signals are blinking fine , the flasher is good . Could be the Winker Cancel unit is bad or both sensor inputs are bad . Does your speedometer work ?
