I am wondering if the PO really blew the Float level this bad.. the Calipers are set at 21 mm and the tab hits about 41 mm.. I notice there is really not much float movement if I adjust the tab to 21mm .. there is only about a 1/16 movement of the float..
could I be confused and the level is measured with the float up and the needle closed. At the 21 mm height the float is parallel with the body of the float.
