UPDATED: I called GM in Arizona, and the man said it you are using Dex Cool, the Bottom procedure would also work on removing it.
Begin with the engine cold and ignition off. Remove the radiator cap. Make sure the engine is cool. If the radiator cap is too hot to touch, your engine is not cool enough.
Open the drain-plug at the bottom of the radiator and drain the coolant into a bucket. You will want to dispose of the cooling fluid as environmentally conscious as possible. So, if there are any shops or recycling places in your area that take old coolant give it to them. Make sure you keep the fluid away from animals!. Don't just pour it on the ground. Animals tend to want to drink it, but it will kill them.
Close the drain-plug and fill the radiator with distilled water.Let cool
Start the engine and let it get hot. Drain. Add distilled water. Do this 2 times before adding any system cleaner. Remember to let engine cool before ading any distilled water. (I recommend Peak Super Cleaner/Flush) and Add cooling system cleaner andrun the engine at 2000 rpms for engine 15 minutes (or as per the instructions on container).
Stop the engine and allow it to cool. Drain the system.
Close the drain-plug, fill the radiator with distilled water and let the engine idle for10 -15 minutes.
Repeat step No. 5. Close the drain-plug.
Install new 50/50 mixture of water and ethylene glycol antifreeze/coolant. Be sure you use the same coolant as was in your Wing. Many of the coolants that are designed to last 150,000 miles will react with cheaper coolants and cause corrosion of the radiator. The best way to do this is match color.
Remember toclean your resivor with distilled water
DO NOT USE DEX_COOL IN ANYGOLDWING
Nightrider1
Nightrider1
