I changed the 55 watt bulbs for 35 watt equivalents and changed the headlight bulb to a HID conversion and that solved my problems
This is your best option as the HID headlight will only draw 35 Watts rather than 55/65 or higher if you put in higher Watt headlight bulb and they light the road better. Use a bi-zenon HID kit with slim ballast. And change the bulbs in the fog lights to 35 Watts each.I changed the 55 watt bulbs for 35 watt equivalents and changed the headlight bulb to a HID conversion and that solved my problems
