I have an 02 and cannot find an answer to my question. Will the foot warmers on the newer models fit the older bikes? Has anyone tried it? I know the control would be a problem, but I can overcome that. A yes or no would do. Thanks
I know that the lower fairings where the toe warmer doors are located are different only because the non-door lower fairings are separated by designations of 2001-2005 and 2006-2008. Other than that I have no idea.
Anything can be made to fit. You would need the two lower fairings plus the new 06 top panel. This may be a problem on the 02 as it is different. In fact the more I think about it you would need the whole of the top shelter including glove boxes etc.
They will bolt up but you have no way to control the doors on your '02.
Thanks Jackjohn.
I think I can mount the control on the lower right panel. I just needed to know if they would bolt up.
Thanks again
